[ QUOTE ]
b2eze said:
Guys, C mag tail threads are not 1 1/8- 20 (Too big)or 1 1/16 - 20 (Too small)and near as I can tell there's no "special tap" in between! I suspect they use the ID of whatever tubing blanks they start with CNC lathe the threads and match the tailcaps ... A custom tap is beyond my means so I guess I'll have to learn to thread with my lathe! Good thing MSC doesn't hassle on returns!
[/ QUOTE ]
Wow that is odd. A size between 1-1/16 & 1-1/8?? That's a first. Yes it was a good thing MSC doesn't hassle on returns. Hope there's no tension felt towards me!
So now guys, well all have to thank b2eze for figuring out that there's no tap (other than custom made) available for MagCs. Chances are, I bet goes the same for MagDs. I should go and edit my post above so no one else makes the same mistake. So know I must find my post on looking for someone with a lathe to shorten & thread my Mag2D and give it a bump.
[ QUOTE ]
Chop said:
What's the best style of tap to get? Plug? Bottoming? Taper?
[/ QUOTE ]
If the threading is flashlight related, it's best to stick with plug taps if your cutting thread that doesn't exist and these are the most common.
Plug taps are the steepest of the three meaning which will start cutting the full threads after a couple turns. Perfect for instance threading the back of a battery tube for a kroll.
Taper taps although can be confusing by their name aren't as steep of a taper as plug taps. This makes it easier to tap into a hole straight as opposed to plug types. I say plug taps are better for use because we don't want thread deep into the flashlight. Taper taps usually start cutting their full threads way later than plug taps.
Bottoming taps are the least common and barely have taper if any at all. They are used for cutting threads deeper into a hole where the threads are already there. I believe bottoming taps cannot start to cut new threads. I forget.
