Searching through the forums, I see recommendations to use Norland 61 to cover tritium vials for protection. When looking at the Norland site, it stipulates the adhesive needs to be UV cured. I would think that if you do not UV cure the material, it would not fully cure and therefore stay tacky to the touch and attract dirt and debris. Is this what those of you out there that are using it have experienced or does it cure enough without UV so that it isn't tacky? I appreciate your comments.
