Flyingdrums
- Joined
- Apr 18, 2015
- Messages
- 6
My most recent light build. The video is meant to have some "light" hearted humor. :ironic: Includes PWM circuit diagram and overview of the build.
Wow, GREAT project and fantastic video! :twothumbs
Two question:
1) How much does the heatsink heats up? It's huge, maybe there's no need for a fan!
2) Did you use a 44mm lens? i see that almost all project with a 100w led do have a 44mm lens, but i'm wondering what diffecence could it make to use a bigger lens, for example a 77mm one with his reflector. Any idea?
Thanks for watching and commenting. The heatsink does get pretty hot after it runs for a few minutes even at the lowest power. I thought about disconnecting the fan to conserve power, but with the fan pot turned all the way down it is only consuming a watt or two. I figured I'd error on the side of caution by leaving it connected.
Yes, I used a 44mm lens because I had used them in the past for my grow lights and didn't take the time to actually do any calculations, In my grow lights the lenses were narrowing the beam enough to direct the light down, but not too much so that I could have an area large enough to grow at least a few plants based of course on the height of the light, which is right now about 6 feet. The other reason I went with the 44mm is because it was cheap! It wasn't until I took it outside and aimed at the woods that I realized that a collector and a narrower beam would have been more ideal. So maybe I'll modify it in the future and will happily listen to any suggestions you have. As you may be able to tell from the video I'm just trying to have some fun with it while learning something in the process and more importantly encouraging others to do the same. Its one thing to watch things on the internet or read a book, but it's quite another to try and conceive something and then actually build it. I expect to screw something up and that's how I learn.
If even with such a large heatsink te fan is needed ... well ... the power is a lot
One more question if i can: which regulator did you use for your project? in the youtube link i'm following the regulator is a 100w Voltage regulator, but i'm now i'm reading that it's not the best solution...
Any advices?
