battery_bro
Hi guys, I just did a fairly detailed look at the LG 18650 HE2 and the LG 18650 HE4. I only used two batteries, and three discharge tests each. Here are the conclusions:
And does anyone know what difference (if any) is the chemical makeup of the LG HE4 versus the HE2?
Thanks
Full blog post on he4 / he2 here if interested.
- The HE2 was released first. However both cells are from 2013, with only a five month difference in between their release dates.
- The second HE2 discharge test is not clean, indicating a possibly lower quality cell (or maybe it's just a problem with my equipment).
- The HE2 heats up faster than the HE4.
- The HE2 has to be drained all the way down to 2.0V to meet its nominal rated capacity, whereas the HE4 a more reasonable 2.5V.
- The HE2 is not as capable of high-drain (20A) discharges, having been rated at only 200 cycles for (15A), whereas the HE4 is rated at 200 cycles for (20A).
- The HE2 I tested is lacking quality control markings which the HE4 and many other commodity cells employ.
Thanks
