Re: power sipping AA?
any thoughts on a super efficient AA led torch, likely 2 AA
I mean at usable lumens, most will last 100 's hours low down on firefly, but something in the walk about 50-100 lumen range
I think you'll find that most modern lights of good quality (something in the $50+ range) with an XML2 emitter will give similar efficiency in that lumen range. You'll get something around 125 lumens per watt of efficiency, out-the-front. Any of the major brands recommended here will give you that. Stay away from no-name brands, or major brands found in hardware stores. Fenix, 4sevens, Sunwayman, Armytek, Zebralight, etc., are all good. (Though Zebralight doesn't have a 2xAA version.)
So, you can get pretty much any light from those brands. Most will have a medium or high mode that will serve you well. Instead, concentrate on quality batteries with reasonably high capacity. I recommend getting Eneloop Pro NiMH rechargeables. That will give you about 2450mAh of capacity, which will run a 2xAA light for about 7 hours at 100 lumens, or 15 hours at 50 lumens. Energizer lithium primary batteries (disposable) may give you a bit more run-time, but they'll be costly to use on a regular basis.
In summary, find a light from any of the major brands with an output mode you want, then get some Eneloop Pros to run it. Alternatively, you could go with a 18650 lithium-ion based light for additional run time.
