Gemman Aster
- Joined
- Mar 28, 2015
- Messages
- 7
I have just read a discussion on 18650's and the need for a protection circuit - or lack of need. Apparently, depending on the torch in question and the quality of the charger used then a protection circuit is often considered an expensive and unnecessary premium. I am told this makes it much cheaper to buy panasonic cells directly.
For charging I use an "XTar VP2" and am considering picking up a "Fenix PD35" to directly replace my VERY low quality 'UltraFire XML-T6'. Given this combination of charger and torch would it be safe to buy the cheaper, good brand panasonic cells? As things stand three AW branded 18650's actually cost more than the torch itself! If I could cut down on the battery outlay without losing either safety or run-time then it would be very welcome.
I welcome you chap's advice.
