Hey,
this is just a little show and tell of what I did with my Sunwayman V11R Mirage.
Just a build for fun... not for long time use... but you could do much better
I was looking at the bezel of the v11R and held a Carclo triple optic next to it.. and though.. hmmm that looks like it will fit.
(you could just file them a little down as well for better fitment)
and voila.. A triple running in my Sunwayman V11R Mirage
Results: a triple SWM V11R... but the output on AA stayed about the same...
See the tools I used. and what I did.
I basically used only 5 tools. Mini vise, big file, small file, soldering iron, dremel.
You could probably do with only 1 file, and without a dremel. The dremel was only used to make the legs thinner on the optics.
The MCPCB is not the one I used.. I already had one pre-fitted with XPG2 and wires.
I put some tape on the optics, to protect them from scratches during the process
Some better ways to do it... PROPERLY
If you want to do it properly, you need better tools..
If you want to run it off 14500 you better make a shelf inside the head that will let the MCPCB touch for heat transfer.
or even add a copper pipe on the back of the MCPCB that will make contact with the mcpcb shelf.
Replace the wires from the driver to the triple. (I just connected the old wires to the triple mcpcb)
Maybe bump the current.
1. So I took the bezel off, and the optics just fell right in... as if it was made for it.
2. Then I took a triple XPG2 on a 20mm Noctigon MCPCB and tried to put it in the head.. (actually the part below the bezel with the fins). But this didnt fit, too wide.
3. So I took out my cheap file, and filed the 20mm into a +/- 17mm (drew a circle on the backside, and filed it by eye)
4. Took the old emitter out, and connected the olde wires to the wires from the triple MCPCB.
5. I also had to file the 3 pins of the TIR optics so they would fit inside the head as well.
(the domes of the optics also are a little too big, so the bezel doesnt fully screw down. )
