FNinjaP90
- Joined
- Jan 8, 2003
- Messages
- 888
I play ultimate frisbee. There are transparent frisbees with a regular LED in the center with fiber optics coming out to the sides to light them up when its night time. They are powered by one CR2025.
But I was wondering, what if you put a 1 watter in there? How resistant are they against shock? Frisbees with a regular LED in there already looks sweet. A one watter would make it like 15 times as bright. This is going to be my first custom LS project, so I want some suggestions. I want to use 3 CR2032's in parallel arranged symmetrically 120 degrees apart in the center tangent to the LS module. A aaa would offset the weight balance of the frisbee since I can't put it in the middle. What should I buy from the Sandwich Shoppe? What should I expect my runtime to be?
I remember that this guy put a 1 watter in an ARC aaa. What did he put in there? Is that available from the shoppe? I want the smallest 1 watter I can get. Hopefully cyan.
Thanks.
Thanks.
