HDS_Systems
Poll: Which battery size would you prefer given the specified assumptions?
A) 18350 given: 1) same overall external flashlight dimensions as a regular 123 model, 2) 45% increase in tactical runtime (79 vs 55 minutes on high setting) using IMR 18350 rated at 800mAh compared to IMR 123 rechargeable rated at 550mAh and 3) shorter tactical runtimes (79 vs 102 minutes on high setting) compared to primary 123 batteries.
B) 18500 given: 1) increase the flashlight length from 94mm (3.7") to 112mm (4.4") compared to the 123 model with other external dimensions remaining unchanged, 2) much better tactical runtimes (153 vs 102 minutes) compared to 123 primary batteries when using ICR 18500 batteries rated at 1500mAh and 3) better tactical runtimes (112 vs 102 minutes) compared to 123 primary batteries when using IMR 18500 batteries rated at 1100mAh.
C) Neither size is of interest to me. If you prefer a size other than 123, please explain in the thread.
