No in fact you said "what cant i see with 450 lumens as opposed to 1100 lumens? the difference really isnt that great in real life use." TEEJ was simply making it clear that some people really do have to see into dark corners in their daily life. Maybe you don't. I have a friend who thought that my 3M which is the XM-L version (The XP-G version was rated at 350 lumens) was more light than he would ever need. The difference is that you see farther with 1100 lumens than you would with 450 lumens. Sometimes that matters outside of law enforcement/military encounters.
I believe I read somewhere that the 3M Pro used PWM which is something I try to avoid when I can. Not sure about the new 3M with XM-L2.
Also...really hate how the forums seem to boot your login after just a few minutes of typing your reply out. Why even have the "Quick Reply" button?
Yeah, its situational. Its like a guy with a 40 watt bulb in his den, and he can see everything in the room by it....and another guy with a 100 watt bulb in the same sized den in HIS house...and they can both see everything in the room.
The 40 watt 450 lumen bulb might not show the detail that the 100 watt bulb could, and, it might be more eye strain to read by if at the end of the room furthest from the light...for both bulb types...but, it WILL be brighter with 1,100 lumens than with 40 lumens.
If its NOT that den, lets say its an entire warehouse, now the "pool of light" each bulb is making is significantly different, with the 1,100 lumens simply being able to cover more square meters with more lumens...its just math.
So to ask "what cant i see with 450 lumens as opposed to 1,100 lumens?" would depend entirely on what there was TO see.
Essentially, with the same beam pattern, you'd see further and more peripherally. If the beam angle was wider, you'd STILL see further unless it was a crazy wide angle, AND you'd see more peripherally.
1,100 L is about 150%
more lumens than 450 L - so its like having 1.5
more flashlights on. (2.5 flashlights total instead of one)
So, if you have ONE 450 L flashlight, its NOT the same as having 2.5 of those flashlights...its just NOT the same.
....two and a half 450 L flashlights will simply show you more than one 450 L flashlight.
And so forth....in real life, the difference IS VERY GREAT....assuming either is "enough".
If looking for your hurt dog, you would be able to pass by where it was laying from further away. If you wanted to see if that was a bear out there, you'd be able to see it from further away. If you wanted to navigate a trail, you'd see more of it at a time and be able to pick your line better, and so forth.
Again, too much light CAN be a problem if its not the right tool for the job...so for CLOSE UP work, no, lower the intensity to avoid glare, etc....use a floody beam to disperse the light to a gentle pool instead of an angry bright dot, and so forth.
But, when you DO need more light, there's not much advantage to NOT having it.
As for PWM, some people are sensitive to the flickering...and some are not...but, most modern lights use such a high frequency that most people would not notice it. I don't remember for the 3M Pro, but I'd guess its probably not a big deal unless you happen to be super sensitive to PWM, etc. One modern one that the PWM can be an issue I did hear about was the Streamlight ProTac 88040 for example, as they used just 130 Hz, which is a very slow cycle that you'd easily see for example.
