6-15-2015
Received my H52Fw headlamp today, my first Zebralight.
Such a compact light, much smaller than I imagined.
No visible exterior blemishes or defects.
Tail threads are gritty.
Tail end has very tiny spots of missing anodizing. Nevertheless, acceptable.
Some lube has migrated to the bottom of the tailcap.
Functions correctly powered by Eneloop. Will test for correct function powered by 14500 in future.
Accurate and even tint to my eyes.
Good beam.
90 degree beam not as wide as I imagined. Prefer even wider beam angle, perhaps 120 degrees of the H502w, but did not want to lose intensity. Nevertheless, acceptable.
Really like the mode options. Outputs below are from ZL website.
In actual use, noticeable but little difference between (H1) 266 lm and (H2a) 163 lm modes.
Relatively more noticeable difference between (H2a) 163 lm and (H2b) 102 lm modes. Strange.
Can do without 266 mode, but nice wow factor.
Little difference between (H2b) 102 lm and (M1) 47 lm modes. Strange.
Little difference between (M2a) 23 lm and (M2b) 11 lm modes.
(L1) 2.6 lm mode is bright, can't look into it.
(L2a) 0.32 lm mode probably most practical of the 3 sub-lumen modes.
(L2b) 0.06 lm mode MIGHT be useful in pitch black up close, VERY close.
Can do without (L2c) 0.01 lm mode.
Personal settings:
H: 266/102
M: 47/11
L: 2.6/0.32
Will turn on and submerge in 18 inches of room temp water for 60 mins tonight to test waterproofness.
Hope IPX rating of 2 meters for 30 mins is true.
Additional Observations/Updates:
6-15-2015
There is a thin, uniform, ring of un-anodized metal (bare AL or SS?) right below the head, around the top of the groove for the clip.
Also similar rings at ends of groove for clip at tail.
6-16-2015
18 inches of room temp water for 90 mins submersion test while on (H2b) 102lm: PASS!
Incidental pseudo runtime test: after 90 mins on H2b: battery indicator flashed 3 times.
Turned out (L2c) 0.01 lm was useful when I needed just enough light to very barely make out known objects within a 1m radius.
(L2b) 0.06 lm was a bit more useful but might disturb others within a 1.5m radius.
(L2a) 0.32 lm was great for moving around the house at night. It might very well be perfect for going to the bathroom at night while remaining half asleep.
(L1) 2.6 lm was plenty for doing many common tasks in the dark.
For me the light is too small to hold comfortably when used as a flashlight for long periods. Index finger keeps getting into the beam. It is a headlamp after all.
But it is perfect as a lantern because it tail-stands.
Like it very much so far.
Small discovery: with the light on, a slow click does nothing.
Personal preferences so far:
Ridges on body and edges on head should have been rounded to reduce wear.
The side button like that on the Armytec headlamps offers better ergo operation than ZL's top button.
6-27-2015
Can run on AAA because spring is long enough. Just don't shake it around too much and contact can be maintained. Handy in a pinch.
Battery capacity indicator seems to test battery based on its voltage.
Good beam.
Personal settings:
H: 266/102
M: 47/11
L: 2.6/0.32
6-15-2015
6-16-2015
6-27-2015
