For sale. USA & Canada only.
Within USA only for posted price
Will sell to Canada for $10 extra for each Barbolights & $15 extra for the MX25L3vn.
Will ship USPS priority with DC in the USA.
"I will take it posted in thread takes precedence"
SOLD $80 Barbolight T-160
These really don't come up often.
Dimensions and weights
Diameters. Head 34.50 mm. Cap 28.70 mm.
Length 111.6 mm.
Weight Without batteries 105 g. Batteries: 1x17 g
Technical features
Body Machined in Al-Si-Mg 6082 T6 alloy.
Finish HA III (hard anodizing). Complies with Mil. Std. A-8625F
Emitter Diode Edixeon KLC8 (6000 °K-7000 °K) ≥ 160 lm
Vision Ergo-Vision vacuum vaporized, high-performance aluminium reflector. Dispersion: 3.5° spot, 55° corona.
Lenses Bayer Makrolon GP polycarbonate. Unbreakable. Scratch-proof.
On/off system Delrin mechanized, calibrated button. Stainless steel contacts. Adjustable switch pressure.
Resistance to immersion 200 m, 20 ATM.
Resistance to impact Military Standard 810-F "Drop Test"
Runtime 80 min at maximum power and more than 120 min overall runtime
T-160 is a compact version of T-04 it seems and I have seen references of it being called "T-04 Compact" as well. I used primaries only as this is what Javier recommended. PM incoming.
Price is $85 $80
For size comparison, Surefire 6Px on top, T160 on bottom
The T160 is on the left, it is visibly a little less bright than the U04 on an 18650, or the surefire.
Items Below are SOLD
$110 with Batteries (USA Only) MX25L3vn MTG2 - The General Purpose light (MODDED BY VINH)
Dedomed & with V54 engraved:
- Current boost from 3.9A-4.3A - 5.5A-5.7A, I can push more but the lumen gain is not worth the heat and reliability risk
- I guesstimate about 3000 OTF Lumen
- Button top 18650 only
- Dedome adds substantial throw and gives a warm tint. I like it but if you like cool tint then stay away
- Light can run 10 minutes straight to uncomfortably hot. I restart turbo every time it step down. Tested at room temperature sitting on a desk.
My last large light (excluding some 2D mag mods). I really like this because it has the control ring that you can turn to where you want it and control where it starts. Comes with the holster.
Price $110 ($110 with batteries (USA ONLY) that have only been used (lightly) in this light, only charged once, they are NCR18650Bs 3400mAh)
$100 Fenix TK35UEvn (modded by Vinh, slight current bump)
I have 2 other MTG2 lights left, both modded by Vinh, this one is going up for sale as well in addition to the MX25L3vn
Fenix build, two buttons on tail, one for on/off. Believe I have the box for this at work. Comes with the holster. 2x18650 light. Sorry about the dust on the light, the light hasn't been used other than in my basement.
SOLD $175 Delghi Iris (Photos soon...)
Here's another light that doesn't come up that often, never thought I would sell it, but it hasn't been used since I bought it several years back. If you want the lanyard in the photos let me know, otherwise it will probably not come with it.
Condition is very very good with no dings/bang/bumps.
XPG R4 Neutral. Made from aluminium 7075-T6 bar, orange peel reflector. Specs below are from original thread
Iris features:
· Buck and boost, dual output driver (625/60ma)
· Runs on primary CR123 3v and single li-ion RCR123.
· Titanium Ti6Al4V bezel
· Dimensions: 101mm long and 28,7 mm head diameter
· 2,85mm thick UCL@ mineral glass with Anti-Reflective coating
· Easy to upgrade, screw-in engine equipped with CREE XP-G R4 bin emitter
· 1,8mm thick NBR o-rings with vanilla scented Italian rubber tailcap boot
· Made in Italy
SOLD Barbolight U04 Atex/P SSC P4
I've got 4 Barbolights so time to let two go, I have carried this one so downgraded the condition from excellent to very good.
Originally posted by toby_pra (4/16/12)
Very good condition, a real divers flashlight, SSC P4 with a great Beam, there is a little
ding in the lens, but does not affect the beam, titanium clip, comes also with box and
papers...can be driven with 1*18650, 2*Cr123 or 2*Rcr123
Price is 95$ $90
I had used the light in a pulp mill and cleaned it up a bit - so there is some water in one of the finned areas shown below.
SOLD C20Cvn $65
C20Cvn XML2 PDTc, Engraved (modded by Vinh) Carried, see black missing from clip, otherwise in very good condition, no dings / bangs / dents, etc.
I find it hard to believe I ordered a PDTc, tint is very nice (I'm a neutral LED guy).
Comes with box / holster / instructions / etc.
Very small 18650 light, side button. Just not my cup of tea (prefer C22C) and have too many lights.
Length 111.6 mm.
Technical features
Price is $85 $80
Iris features:
· Made in Italy
Price is 95$ $90
