What flashlight is this for? Does it have springs at both + and - terminals? Is the clicky switch threaded into the tail,held in place by a threaded terminal that could be adjusted to compensate for the play?sorry for the "20 questions", I am trying to wrap my mind around the best solution. Do you have a set of calipers you could estimate the amount of space you need to compensate for(thinking out loud...could you solder a small spring to the positive end that would keep things in place)? Is there anyway to add a few metal washers at the negative end, held in place by the negative spring to take up the slack? A picture or two might help also....
