Here is a quick review with pictures of the TM16. I will update the post as I find out more about this light.
Beam shots will be done once i get more time. Hopefully tonight.
First thing to notice is its size! Its the largest flashlight I currently have. Very big large diameter quad reflector.
Packaging is just a cardboard box, not very premium for the price we pay.
As you open the cardboard box, you are treated with this after removing a foam protection
Included accessories are shown. I think my lanyard came in 2 pieces
The light itself
The business end. Quad XML emitter, all well squared and aligned.
Tail cap, has a standard tripod mount
More photos of this beauty
Tail Cap connections
Body electrical connections. Does not accept flat top 18650 as can be seen.
Battery polarity indication on each battery slot.
Battery Height on board. Unprotected cells are shorter, so there is a lot of space left to compensate by the spring to close circuit. Batteries used: Samsung INR18650-25
Emitters lit up in lowest mode.
Beam on lowest mode close up
Beam on lowest mode about 30cm/1foot away
Battery voltage illumination
Size comparison to other lights (TM16, TN30, SR52, TK35, R40 Seeker, D40C, JM35, MM15)
Upright comparison (TM16, TN30, SR52, TK35, R40 Seeker, D40C, JM35, MM15)
Body length comparison (TM16, TN30, SR52, TK35, R40 Seeker, D40C, JM35, MM15)
Reflector size comparison (TM16, TN30, SR52, TK35, R40 Seeker, D40C, JM35, MM15)
Close up to similar size/output lights (TM16, TN30, SR52, MM15)
Business end of similar size/output lights (TM16, TN30, SR52, MM15)
Beam shots
Setup:
Tm16 (4000L), D40C (2000L), Sr52 (1200L)
90cm from wall exposure 1/1000 second
90cm from wall exposure 1/8000 second
Outside about 5 meters away
Outside on trees, about 7 meters away.
The light itself
Beam shots
Setup:
