pedalinbob
just an fyi: i have been making some anglehead/luxeon/micropuck mods, and intend to make a few more for family and friends.
the biggest hurdle was in creating a heatsink. it sucks trying to modify aluminum with a minimum of tools, so i have been searching for a stock heatsink that would drop in with minimal mods.
i just found one: from radio shack, part # 276-1363
Anodized aluminum heat sink for TO-220 packages.
it is square, but drops in nicely, avoiding the flat section and positive contact, as well as missing the negative contact at the side. it meets resistance right at a good "focal point" where the optics will not hit the lens, yet it is not too far back into the head.
i slide the heatsink in with the "fingers" pointing outward.
i had concerns about the heatsink being inadequate, but combined with the lux3 thick heatsink and moderate current, it should be fine.
my mod involves soldering the micropuck leads to the contacts in the anglehead.
then i take a star, use arctic adhesive to glue it to a heatsink. then i solder the micropuck leads to the star, and push the heatsink into the body, and use JB weld to hold it into place.
i custom make optic holders for fraen optics by using pvc pipe--it is very easy to cut and file to proper shape.
everything is carefully JB welded together. the idea is to have it as tough as possible.
my prototype has been thrown on a bare concrete floor 5 times in a row--and was only scratched.
for such an easy and relatively inexpensive mod, the results are incredible.
Bob<--really need to learn to take some pics.
