alternety
I have an Ozone generator in the refrigerator that actually (against all of the laws of snake oil) seems to actually keep food noticeably fresher (generally veggies). It uses 4 D alkaline cells. The manufacturer says not to use rechargeable cells. Asking them why was not fruitful. I got many months (>6) of life out of a set of batteries. I am guessing that performance at low temperatures is not good on NiMH. I have found some curves for an NiMH D, but nothing showing how temperature affects the capacity/discharge.
The current is fairly low (I don't know what it is). It tells me when the batteries need to be replaced. This is my first set of batteries. When I removed the D cells, they were all sitting a bit less than 1V. Looking at the curves for NiMH, they should stay above 1V until they are pretty much depleted. Potentially working better than the alkaline.
Can anyone provide some insight on using the NiMH in this application? And if a good brand can be recommended if, indeed, it is a good idea.
