I just got some KeepPower 3.6V 18650 3400mAh Lithium Protected Rechargeable Batteries ( http://www.gearbest.com/chargers-batteries/pp_104176.html ) and am wondering what the best, safe, budget charger is. I also use AW and Ultrafire batteries for my flashlights. I just ordered a Nitecore TM16 and use Lumapower MRVK's. All the batteries I have are button top.
If I'm correct you almost always want button tops and when it comes to protected or unprotected, protected is best if you are going to use a flashlight with multiple batteries and unprotected is fine if you are using a single battery flashlight, is that correct?
Here's a pic of my current charger; it seems like this isn't a safe charger. Is that correct? Should I stop using it? I haven't had any problems in 6 years with it.
My current charger and batteries I'm using:
My AW battery:
I know that there is a lot to learn about batteries and chargers but right now I'm so swamped I just want to learn what's the best, reliable, charger that will fit my needs.
Thanks!
My AW battery:
Thanks!
