If you have any questions please feel free to send a PM or email. Thank you for looking!!
Sale Terms:
2) Milkyspit Arnor Surefire L1 [Sold via PM] $130 $135 $140 $145 $155 $165 $175 $180 $190 $200 $205 $215 $225 $235
Led is a neutral white Cree MC-E with a frosted dome. This spreads the beam nicely and without a doughnut hole that was common in the MC-E due to it being a 4-die emitter. UI and flowchart are listed below.
Tale of the tape:
Full disclosure: The body and light were received in a trade. However, the body was not touched by Milkyspit, only the head. A magnet spacer is used between the head of the light and positive end of the battery. The pocket clip has been swapped to the one-way clip from the Arnor sold below, this one no longer has the two-way clip.
Flowchart: http://i1313.photobucket.com/albums/t554/moshow9/CPF/milkyspit-elm-firmware-v1_zpsektbick5.png
3) HDS EDC Clicky 4500K XM-L2 w/17670 and CR123 body [Sold to monanza] $120 $130 $140 $150 $155 $165 $175 $190
This light was my daily carry for a good while. This package gives the flexibility of a small EDC carry using the CR123/RCR123 body, of extended runtime using the 17670 body. Only one tailcap (extended button version) is included but can be swapped between the two. A second one can be purchased through Henry via the HDS website.
Emitter has been swapped to a XM-L2 4500K for a nice neutral tint. Colored tab inside is Yellow for those that might inquire.
Includes: CR123/17670 body, standard pocket clip and aftermarket clip with screws.
Full Disclosure: Body shows some wear and lens might need to be replaced as the AR coating is wearing off and looks a bit cloudy/smudged in certain angles.
Programming manual is not included, as it was not received when I purchased it - however, it is available on the HDS website here:
http://www.hdssystems.com/Products/Legacy/Clicky/Clicky2UsersGuide.pdf
1) Milkyspit Arnor Surefire L1 [Sold] $175 $185 $200 $210 $220 $230 240 $250
Led is a neutral white Cree MC-E with an frosted dome (difference between this one and the one listed below is this one is not as pronounced, but still eliminates the donut center that was common with the MC-E emitter). UI and flowchart are listed below.
This one has the complete body as modified by Milkyspit - no magnet needed as there is a spacer inside the top part of the body to make the connection. See comparison photos (this light is always on the top or right side and not the one with the glow in dark o-ring on outside of head)
Tale of the tape:
4) Surefire E1e Black/Orange Cerakote [Sold to Jvvjvv] $160 $170 $180
While I had intentions of replacing the bulb with another dropin/module I never got around to it, nor did I carry it. Switch is stock Surefire clicky switch (not a McClicky). Dropin/Module is a 3.7v bulb, single mode output at around 90 lumens. Includes IMR 16340.
That said, there are a couple of dings on the bezel - these are covered by the cerakote. There is also a small mark on the head and some slight imperfections on the reflector and lens. Apart from the mark on the head, I could not photograph the imperfections on reflector and lens. I attempted to photograph a beamshot to show these.
Sale Terms:
- Priority Mail shipping included within the US unless otherwise specified
- US Sales only
- Paypal Purchase of Goods Option (no gift payments please)
- Paypal payment must be received within 12hrs unless previously discussed
- I reserve the right to refuse sale at my discretion
Tale of the tape:
CreeMCE-5KB PermaFrost KL4cut
Acorn NR 'Elendil' eDaptable
CopperUniSink DRC 16ohmTail
Designatedfor
1xIMR16340
ONLY
Designatedfor
1xIMR16340
ONLY
Tale of the tape:
CreeMCE-JE6 PermaFrost
KL4cut Acorn NR 'Elendil' eDaptable
CustomAlSink DRC 16ohmTail
Designatedfor
1xIMR16340
ONLY
Designatedfor
1xIMR16340
ONLY
