Hi there,
I've been lurking for a while but I am otherwise new to the assemble-it-yourself flashlight thing so please forgive me if this is a dumb first post... I decided to get my feet wet with a Soloarforce L2M host to run in the single CR123A configuration.
I am looking for a drop-in with the best balance of durability, runtime (as long as possible with a linear drop-off), and beam pattern (I like a fairly tight / focused center beam, with moderate spill) for a tactical/EDC single-cell light. I'm not overly worried about the actual lumen output, but obviously the brighter the better as long as my other criteria are met first.
With the aforementioned in consideration, would I be better served by an XPG R5 .8-4.2v drop-in, or an XPL V3 2.7-9v drop-in? Will the higher voltage XPL do ok for my uses, or will it be handicapped by the single cell configuration and drain the battery much faster than the XPG?
If neither of these Solarforce modules are my best option, I'm open to suggestions also. I am on a budget, but I'd be willing to spend about $40 on the drop-in if it made a real significant difference. I am familiar with Malkoff, but I think they're a little overkill for my first one. I want a durable drop-in, but it doesn't need to be bomb-proof necessarily.
Thanks for any help!
