Actually in some cases batteries differ in voltage output and internal resistance which can affect the brightness of some torches.I do not think a battery can make a torch brighter. I think it is the electronics inside and the led what determines that. More mAh means it holds more energy.
Yes, it can. The type of battery (internal resistance) determines the max. amount of current flow that the battery can handle. If this is the limiting factor in a flashlight, then a battery with less internal resistance will provide more light.I do not think a battery can make a torch brighter. I think it is the electronics inside and the led what determines that.
This is very unlikely that this will last for more then a few seconds. Don't be fooled by the given 1.5V/1.2V specs. My rechargeables come with 1.45 V off the charger. The internal resistance of a alkaline battery is much higher then a NiMH. Additionally, under high load the alkaline battery will have fast a lower working voltage then the rechargeables. NiMH are generally the better batteries then alkalines in terms of overall brightness.Actually, I think I can tell a slight increase in brightness in my Olight i3s EOS AAA light when I use a 1.5V alkaline rather than a 1.2V NiMH rechargeable. The extra 0.3V is a 25% increase.
LoL, luckily I said that I think.
No problem, my friends.
Milliamp-hours is a combination unit. There is amperage (current flow) and there is time (hours.)
It is quite possible to have very low voltage and very large milliamp-hours. (CPF search: zamboni piles.)
It is quite possible to have high amperage, moderate voltage, and small milliamp-hours. (CPF search: lion nukes.)
It's quite possible to have low amperage, high voltage, moderate milliamp-hours. (Internet search for 9v battery welding.)
It's very difficult (from an engineering standpoint) to do all of things and do them safely. Much of technology is either concealed behind safety or on the razor's edge. What is the razor's edge, you may ask? It's when safety margins are compromised in the name of performance. In short, it's the bane of every flashlight manufacturer engineer and and delight of every void-your-warranty flashlight modder.
I uhh... kinda sorta know how to make blasting caps maybe kinda. I still have both eyes and all fingers (and toes.)Always With the "safety"... Blah blah blah. Play with blasting caps. Swim after a big meal. Ignore common sense ... Future generations will thank you.
That is all.
