I am pretty sure my two battery (Li-ion 1685) flashlight has a faulty clicky switch.
Due to it's very erratic performance I can't be sure how many modes or even if it's forward or reverse.
The Tailcap when removed reveals a switch module that comprises an aluminium body with protruding brass cylinder about 5 mm in Diam.
the aluminium body is screwed into the Tailcap housing by two drilled "holes" obviously designed to be inserted & removed with a special tool.
the thread inside the Tailcap measures 23 mm in Diam.
I don't want to discard this quite powerful flashlight but it is near useless as is.
How do I get the damned thing apart so that I can at least measure it or provide pics to help ID the type?
Thanks
Thanks
