Hello everyone. Haven't been around CPF in a little while but I've been obsessing about lights again, so here I am!lovecpf I'm looking for some advice; recently I dug up this old thing:
[hotlinked pic deleted]
It's a Surefire G2Z LED Nitrolon Combatlight. It's kind of old, new enough to be LED but pretty low output by modern standards and biased a bit more towards cool than most SF lights I've owned. But hey, it's still a Surefire! Great build quality and very solid. It occurred to me that I could give this light a new lease on life with a Malkoff dropin. After e-mailing back and forth with the folks at Malkoff (thanks for the help, sir!) it was determined at an M61 is the right model for my light.
Ah, but which one?
I can narrow it down a bit. My G2Z is only one mode, so I only need one output level. And I generally like lights biased towards the warmer end of the spectrum, or at least neutral. So I can probably narrow it down to the M61N or lower down the page. But I'm having a bit of trouble deciding between the various options. Probably I don't want the very lowest (if I did I'd just stick with the current emitter). Ultimately it depends on what I decide to do with the light. I've got some very powerful WMLs so I don't plan on weapon mounting the light. I've got a number of really small EDC sized lights (2 x Surefire E1b, 1 x JETBeam BC10, 2 x Streamlight Microstream and an Elzetta Alpha on the way) so EDC is covered. I've got a couple really powerful (by my standard) lights like a JETBeam BC25 and BC25SE. So this might be a vehicle light, maybe a bump-in-the-night light to keep by my bed, maybe a general utility light. Really I'm open to suggestions!
So what do you, the CPF members, suggest? I'm not sure if I want a light that I can't run for long periods due to head (metal head but nitrolon body). On the other hand, realistically I don't generally use a light that way. If I was using it to change a tire or handle some other roadside emergency though I could see setting it down and letting it run long term.
The more I think about it the harder it is to make up my mind!:sigh:
I could definitely use some suggestions.:thanks:
Ah, but which one?
