that photo and label was the reason why I was confused. I doubt this light will have a built in diffuser as most other Eagletac lights that have a diffuser have their model numbers end in D or clearly mention diffuser. If this light does get that two button UI and comes with a Cree MT-G2 Led as mentioned in manual then it's going to be perfect light for me to use as a photography light. Infact even in the manual of Dx30LC2 eagletac has mentioned the Dx30/PX30 mini and regular models, which means that the D25/P25 regular and mini are on their way out to be replaced with new UI. can you confirm that these new lights have a mode memory? manual is very ambiguous in that regards.
