WarRaven
I was wanting to look at something a couple times recently in a dark street and having lots of lights makes it easy to light it up and view your target let's say.
Though, if you're wanting to be a bit discreet about it,
it's near impossible to fire 1000 lumens level to the ground and not light up everything around you, and then some.
Even with a dedicated thrower there's plenty of spill to backwash your eyesight and light up your local area instead of far away.
That's life yes but I want a solution, temporary one, and I'm happy to play around with my chicken bones and tea leaves looking for a solution.
Well it's obvious moving light further into head is solution, adding a tube to absorb spill leaving hot spot to break out end.
I haven't found a suitable rubber yet, I want this to pop on and off at a moment's notice. Though I found if you remove head of an old incandescent MagLite, remove lens and reflector, it matches the end of my Fenix PD35 fairly good.
Yes I know, that's just junk Raven, but I'm not suggesting this for everyone as it is pure spotlight and is sub par looking.
Though, in a pinch, a wrap of black tape to secure it to light and the lower head can be unscrewed to give most of the spill back or use the entire head assembled on the front of light for spot only.
I've grabbed some beam shots on floor in my garage, laugh, but don't laugh too hard ☺
With and without, side by side..
Complete MagLite head, gutted an inverted..
I may ream inside.. Idk.
Low power, cone end off..
Low power, cone end attached..
High power cone end off...
High power, cone end attached..
Well if anything, it'll give you guys something to giggle about.
I'm not claiming I invented or done anything non of you have, just sharing my redneck RavensEye idea with you.
Have a great one all.
