Thank you. This is interesting. I wonder if all the manufacturers are taking the readings at start up or after 3 minutes of startup for the output to stabilize after battery resistance cuts in? That will make a real difference, maybe not much but still a difference in the actual throw.
From the linked site:
Light Output
Total lumens of output, measured in an integrating sphere after the light has been on for 30-120 seconds. 30 seconds gives a little time for the LED to get hot and the battery voltage to sag which will usually result in a lower output number.
Runtime
The amount of continuous runtime (in minutes) until the light output drops to 10% of its original value (measured 30 seconds after turning the light on).
This test is done using the batteries included with the flashlight.
[1] If no batteries are included, the test is done using the manufacturer-recommended batteries.
[1]
The test is done in an integrating sphere just like the lumen test with light output measured every 15 minutes. 10% of brightness probably gives inflated runtime numbers. In the past, some testers used 50% to be a little more practical, but with most batteries, the drop-off is usually pretty quick and the time between 50% and 10% usually is not long.
Forgive me. I'm a simple mind and can only go by printed standards. I'm also of the simple mind that when I turn a flashlight on, does it make me smile or do what I expect it to do. Last night I was out walking in the mountains with only the aid of a headlamp (a flooder was in the back pocket) and when I turned the headlamp off, the dark slammed down like thunder. The point, I use the light as it's the light that lights the way, not specifications. Between the dark and the headlamp, I was very pleased with what I was being shown. Besides my mind, what am I missing?
Disclosure; using a freshly charged Orbtronic 3400 mAh 18650 battery.
