CNCUnlimited
- Joined
- Aug 21, 2015
- Messages
- 2
Hello all,
I have a machine that currently uses a mercury vapor arc lightbulb (sah-250b). It appears to be rated at 10,000 lumens. These bulbs are obsolete and expensive ($500-$700) to replace. I would like to replace it with a suitable LED, but I am not well versed in the finer points of LED specifications and would like some feedback from people who are.
The machine is an optical comparator used for precision measurement. If you google "optical comparator" and select images, you will see plenty of examples of what it is and should give you an idea of what it does.
Some questions I have off the bat are, I think I need a single emitter light source due to the light being lensed into a parallel beam and then projected onto the screen. I believe multiple/large emitters would have issues working with the existing optics. Thoughts?
Also, due to the high magnification and numerous optics involved, it takes a really bright light to get a visable image on the screen. I'm not sure you could have too much light, but a dimmer is probably necessary as the magnification is variable.
So, having said that, doing some research, it seems the CBT-140 from Luminous seems to be a possible candidate. These suckers are expensive at nearly $100 a piece, otherwise I would just buy it and try it.
So, what do you ll think? Am I on the right track? If so, I could use some help selecting color/flavor as I have NFI what all the nomenclature means. Also, I need some ideas on how to power it.
Thanks in advance for any insight.
Brian
Brian
