Hey guys
after you all recommended me a pair of flashlights which i am absolutely over the moon with - exceptional performance (THANK YOU! )
i've gone all-out and bought myself a box of genuine surefire CR123A batteries and an intellicharger I4 as i wanted best performance for my lamps
however i've come across a strange "bug"
i find the intellicharger has taken a disliking to some random batteries, say the indicators are as such
1=1 light
2=2 lights
3 = charged
the flash pattern will show 1 1 1 1 1 1.....2 2 2 2 2... then at random, 1 1 1 1 1 1.... 2 2 2 2 2 < -- never reaches 3
now taking them out and putting them back in again results in returning to 1 flashing - soon turning to 2 again
thinking it was a connection issue - i've gently bent the tabs forward a few degrees to really make sure the batteries are in there good and snug - this seemed to help the issue a bit, however they seem to just be flashing at 2 2 2 2 2, i've actually fully charged several batteries while a dodgy one is just sat at 2, i removed them after i felt they were becoming significantly hotter than the other batteries which reach full charge
i set to and started changing channels with a single dodgy battery - after a while, hey presto it showed 3 lights stable - full charge
i'm not sure what that's all about - can anyone shed some light?
Are surefire CR123A subceptible to dodgy cells or is it the charger? or am i being impatient or something
just put 3 on charge, the 2 bar on far right is a known "dodgy cell", the three 1bars are showing 33c(93f) and the 2 bar (dodgy) is showing 54c (130f) - all on charge for the same ammount of time (about 15 minutes)
Thankyou all in advance
edit: 20 minutes later the dodgy cell reached 60c (140f) at which point i disconnected it, only charging the 3 good ones now :s
in spite of removing bay 4 battery very carefully, being careful not to move the unit at all, the battery in bay 2 stopped flashing (0 lights on) for a few seconds then resumed flashing 1
1=1 light
2=2 lights
3 = charged
