edwardmatt83
- Joined
- Sep 2, 2015
- Messages
- 6
Hello,
First time poster here. I got this flashlight yesterday to use as my bike light. I typically ride at 5:30am and need some good lighting this time of year. I usually ride for about 2 hours. I was excited when I found this light, it looked perfect for my needs. I am using Panasonic NCR 18650PF Protected 2900mAh batteries that I got from mountain electronics. The batteries were fully charged, but I only got an hour on high from the first battery that I used. It completely shut off by itself and I loaded my second battery in to finish my ride.
I have a few questions...
What battery do you recommend for a longer run time? Will I get a lot more time out of a 3400mAh battery?
Do I have to use protected cells with this flashlight?
How easily can I program the light to something slightly less than the highest setting to get longer run time? I would gladly knock the 1100 lumens down to 1000 or 900 if it meant I could get significantly longer battery life.
Thanks for the help - I love the light so far!
[h=1][/h]
[h=1][/h]
