Not sure what you're asking, but as general rule a good current regulated driver needs a certain wattage (VxA) to produce a fixed output. So for a fixed lower output on a NiMh, eg, 1.2Vx1A=1.2W, the draw on a 14500 would be ~324 mA, (3.7Vx0.324=1.2W).
As far as most powerful,
An IMR 14500 (AW for eg) is rated for 3.7Vx4A = 14.8W
An Eneloop 1.2Vx6A = 7.2W
An ICR 14500 3.7Vx1.5A = 5.5W
An L91 Lithium 1.5Vx3A=4.5W
Alkalines have very low capacity and very high internal resistance at high draws and therefore will perform worst at high outputs... but they will probably outlast all the above at the lowest draw levels. Also, boosting ~1.2V cells up to Vf tends to be less efficient than bucking 3.7V cells down, so an ICR 14500 and Eneloop will actually be very close.
