tommy_vercetti
- Joined
- Sep 20, 2015
- Messages
- 5
Hi all,
I have 3 50W RGB Flood lights I'd like to repair. I was looking on Ebay and I can buy a new diode and driver for $23. http://www.ebay.com/itm/One-50W-COB...-controller-/262043956084?hash=item3d03097374
But I thought maybe I could do it for less $$$. I don't care about the remote or adjusting the color/brightness. I just use these floodlights at full brightness with all three colors (in other words the "white" color setting with full brightness.) I plan to add more, so fixing these cheaply is a premium. I prefer the color of the RGB's at full "white" brightness over the cool white or warm white colored lamps. I use them above my fish tanks (firmly installed into strong canopies.)
2 of the lamps I am trying to repair seem to have good diodes. Therefore I am guessing the driver is bad. When I plug them in they flash brightly and then go out. One of them will actually put out light for a few minutes before going out.
The 3rd lamp has a bad diode, I suspect. When plugged in it flashes red, and the rest of the diode looks slightly charred.
These are Loftek lamps I bought on Amazon. The metal housings are in perfect condition, and are standard in size. Loftek lamps include a standard 110v American plug.
Can you use any 50W LED driver on an RGB diode if you don't want to control the color/brightness? Do any of you recommend a good replacement driver? How about a replacement RGB 50W diode?
Thanks,
S
Thanks,
S
