Timothybil
Was wandering through the Nitecore web page this am and noticed a new light - the HC20 cast aluminum head light. This is from the announcement page:
The huge success of Nitecore's unibody die-cast flashlights EC4 and EC4S does make flashlight fans wonder what will be the next product that embraces this innovative technology. Today, we take it to our other proud product line, the headlamp series, and bring to you the featherweight HA20 headlamp.
Made from the rugged aerospace grade aluminum alloy, HA20 possesses a major housing manufactured with the same technology that is used in high-end fields such as Formula-1 racecar engines and spacecrafts. It is more sturdy and compact than most plastic headlamps you can find in the market. In addition to its light weight, HA20 also features an extremely fast heat dissipation thanks to its low heat-resistance metal housing. Along with effective cooling fins and Nitecore's classic Advanced Temperature Regulation (ATR) technology, HA20 is able to adjust its brightness output based on internal temperature detection, only to provide its best performance while keeping your forehead cool all the time.
We add both ruggedness and coolness to HA20 to build up your utmost enjoyment in using. Of course, making your enjoyment continuous is our other mission. Therefore we decide to utilize two universal, inexpensive and accessible worldwide AA batteries, and also allow for two rechargeable AA Ni-MH batteries. You can buy substitute batteries almost wherever you go with HA20.
HA20 employs a CREE XP-G2 LED to emit up to 300 lumens white light for your exciting outdoor quests. Meanwhile, two red LEDs on both sides significantly enrich HA20's application scenarios, such as sending SOS signals in emergencies. As your best outdoor partner, HA20 cares more than illumination: it also displays the power levels of your batteries as a portable multimeter. With the powerful yet lightweight Nitecore HA20, you can go anywhere and enjoy continuous illumination.
It will be interesting to see what the price point is for this one.
