I picked up a Streamlight TLR-1 HL today even though I had previously written it off due to the odd tint and beam pattern I see in most reviews. No one ever mentions it, it's just something I noticed. I'm already a fan of Surefire products, so I decided on a Surefire X300 Ultra, who's size seemed to be the only negative.
Today I decided to check out the TLR-1 HL in person at local dealer, and even though the display model had the same purple tint and squarish, lopsided beam pattern, common sense kicked in and I decided for its intended use, it would be a non-issue.
The one I purchased, however, seems to be an updated version. The center of the optic, which covers the LED is frosted. The tint is much nicer than the display model as well. It's more neutral with only very slight hints of violet in the outer spill.
Here's a pic of the optic
And a daytime beams shot on a tan dash panel
And some random pics of the optic and beam I googled of the older version
The compact size of this over the X300 Ultra are a plus as well. I programmed out the strobe as soon as I opened it since I have zero use for it. I just wanted to let you guys know about the improvements I noticed after purchase. Thanks.
