Im interested too! I have a d10 with golden dragon led, so maybe xpg 2 would be best in my case? Is it a 166 mm board?
This thread here details the process of taking apart the D10 to access the pill and led. I will urge caution in that removing the brass ring is the most difficult part and care must be taken in this step. Too much force on it could cause it to lose its shape and not work properly after reassembly. I recommend using something to get up under the edge of the brass ring and gently pry up on it, working in a circle until the ring pops loose. Some D10 lights it's fairly easy and others it takes awhile. Once you get the ring out you can use needle nose tweezers to put in the two little notches on the outside of the circuit board/driver and gently twist. Some models have thread lock so it may take a little force, just be careful not to knock loose any of the chips from the driver.
After you you get the pill out its an easy process of desoldering the original led and putting a new one in. I believe the largest size led star that can be used is 14mm, which seem hard to find. I used 10mm copper for mine but if you can find a 14mm that would work better. Richard at mountain electronics does sell a 14mm star with XM-L2 mounted. It has a nice color temp of 4250-4500k and good CRI for less than $5 which I would recommend. I used one of these in my D10 with excellent results.
Regarding emitter for your golden dragon, definitely use a xp-g2 or Nichia. Any other emitter would be too large for the reflector without modification.
