Wuben
Page 9 of 9 FirstFirst ... 23456789
Results 241 to 260 of 260
Thread: New driver from RUSH for the 1x123 "E-Series" lights.
  1. #241
    Default Re: New driver from RUSH for the 1x123 "E-Series" lights.
    @Rush
    Any updates on new driver?
  2. #242
    Aug 2013
    Land of the rising sun
    Quote Originally Posted by ironhorse View Post
    Are these reverse polarity protected? Could I just flip the battery over to prevent it turning on?
    rush,
    I never saw any confirmation on this.
    If an RCR123 is inserted the wrong way, would it damage the light engine and/or LED?
    Ultimately I always saw this as the biggest failure with the S3 driver design.
  3. #243
    Flashaholic rush's Avatar
    Mar 2008
    Germany
    GoVegan,
    the Hive drivers are all reverse polarity protected, you don't have to worry about inserting a battery the wrong way.
    id30209,
    there is a working prototype of the new driver but i am not happy with the performance yet, so more work is needed on the design.
  4. #244
    Quote Originally Posted by rush View Post
    GoVegan,
    id30209,
    Thanks for the update. This is the only thing that has my interest on CPF so I'll be interested to see a successful result.
  5. #245
    Mar 2008
    Germany
    Thanks for the encouraging words F89, i certainly do my best to improve on the shortcomings of the current HiveLD. I would be another happy user
  6. #246
    Hive is awesome as it is now but getting it better it would be amazing.
    Thx Rush!
    Sent from Tapatalk
  7. #247
    Thanks for your efforts more importantly.
    I've been waiting patiently and quietly but I must say that I'm pretty keen to see your revised driver in production. For now I like to think that you're tinkering away and perfecting it .
  8. #248
    Hi, I'm looking at ordering a haiku but read about the hive pwm issues on low lumen settings. I'm just wondering when rush does update things to address this issue, does it mean new hardware? In which case I might be better off waiting for the update before I order the haiku?
  9. #249
    Quote Originally Posted by monty94 View Post
    Hi Monty,
    As far as I know it will mean a new light engine (hardware). The good part is that it's easily removed/replaced (with some minor considerations regarding the Haiku reflector).
    The Hive is a really excellent driver but, like you, I had my concerns regarding PWM and it wasn't for me. A reworked one will be a really good thing.
    I have a fair handfull of McGizmo lights (including 4 Haikus, sounds incredibly greedy), all of which have the 3S light engine (no longer available) and AA light engine.
    I held out quite a while intending to get a Mahi when the new Hive came out but I recently caved and ordered one with an AA LE and 1xAA pak which is actually not a bad combo, I did however promptly swap in a 3S (AA LE went to a Sundrop along with 1xAA pak) and put it on a 1x123 pak.
    My EDC is a Haiku 1xAA pak with AA LE (119V) and I can't rate it highly enough. The Haiku is my favourite light of all time.
    My Haiku set ups include: 1x123 with 3S XPG2 (newer smooth OP XPG reflector), 1xAA with AA 119V (newer smooth OP XPG reflector), 2xAA with 3S 219B sw45k (not a stock LED with XRE/XML reflector) and 1x123 with 3S 219B sw45k (older heavy OP XPG reflector).
    Many happily use the Hive in it's current form and I have to say that it has a lot going for it but if the PWM on low modes is a non starter there's always aftermarket LE's (they'll likely be 4.2V only, which for me is a disadvantage), or you could seek out a used 3S? Then there's the AA LE, it doesn't have a stack of lumens but it's incredibly capable (and versatile).
    While I really like the Haiku on the 1x123 pak, I'd have to say the 1xAA with AA LE is a wonderdul thing.
    Not sure if any of my ramblings help (or further confuse?) but I encourage you to continue your interest.
  10. #250
    The only problem with PWM is ultra low levels which you wonít see or use if you choose standard 3S operation in UI.
    Thatís why i donít see any flickering in my setups but iím not using super low levels at all.
    For night expedition iím using 660nm red light.
    Sent from Tapatalk
  11. #251
    Quote Originally Posted by id30209 View Post
    The only problem with PWM is ultra low levels which you wonít see or use if you choose standard 3S operation in UI. Thatís why i donít see any flickering in my setups but iím not using super low levels at all. For night expedition iím using 660nm red light. Sent from Tapatalk
    Thanks for sharing your thoughts id. Perhaps I should have mentioned that the 3S also uses PWM on it's lower modes, I'm quite susceptible to PWM but I don't see it on the 3S and don't think anyone would. The current Hive however, the PWM on low modes was quite obvious. I used to use 660nm red in the army, it's pleasing on the eyes but terrible as far as being monochromatic and tactically pretty useless as even tiny amounts of red light (any light) literally light up like a Christmas tree when using NVG It does a pretty good job if used low enough not to mess with your dark adjusted eyes but then again so does white light if used low enough (needs to be quite a bit lower than 660nm). Currently I don't find I often need moonlight levels. That said, if the reworked Hive came out I'd snap up a couple for its moonlight ability amongst other things.
  12. #252
    Quote Originally Posted by F89 View Post
    So reading through this, yall only see the flicker (PWM) through bridging the contacts and accessing the lower output settings? I just got my first Light from Don, and I can't see any flicker on the lowlow setting..... ETA: Haiku/HIVE/123/Nichia119v
    thanks!
  13. #253
    Quote Originally Posted by Scout1 View Post
    thanks!
    Yes and no.
    Yes, I bridged the jumper on my Hive to be able to adjust the settings. However, I found issues at levels equating to higher than the lowest setting of the 3S (25mA).
    You'll need to read through this thread if you're interested in the issues that have been raised. If you're happy then that's the most important thing for oneself.
  14. #254
    Ok thank you for the info! Glad to be learning all this. Ordered an AA mule so Iíll have both engines!
  15. #255
    No worries.
    Nice one, enjoy.
  16. #256
    Very helpful, I always enjoy reading your posts and actually came across another of your post raving about the 1xAA + AA LE on the Haiku. That has swayed me and I've gone ahead to order an AA Haiku with Don. I did opt for the osram LED as I'm curious about it and we're spoilt for choice popular Cree. But then of course the cree are popular for a reason, so I might regret the osram?
    I do already own a Mule 1x123 with 3S 119V. If I do feel like it, can I swap the 123pak and 3S 119V into the Haiku head and effectively have a Haiku 123 w/ 3S 119V? Will the reflector in the Haiku be compatible such that the result is exactly the same as if I'd other that configuration new from Don? And vice versa, if I swapped over the 1xAA w/ AA Osram into the Mule, will it be the same?
    p.s Does that mean I could also then mix the 1xAA pak with the 3S 119V + Haiku (or Mule) head and be able to run 14500 cells? And would a 3S 119V + 123pak allow me to run CR123 primary?
  17. #257
    Crackup Re: New driver from RUSH for the 1x123 "E-Series" lights.
    I'm glad you've enjoyed my ramblings.
    Hopefully the following will answer your questions.
    The 3S can run on on roughly 3 to 4.2V (exact figures can be found in the forum). This means yes to Li-ion 4.2V (16340, 16650, 14500), CR123 primary, CR123 lifepo, 2xAA lithium primary, NI-MH and even alkaline.
    The AA converter can accept all of the above plus of course any flavour single AA although I wouldn't recommend going above 3V as the excess voltge is clipped as heat, but single CR123 primary or 2XAA etc are fine. I personally use mine for single AA NI-MH or lithium primary.
    Regarding LE changes on the Haiku, the main consideration is the reflector type. As far as I know the 119V, XPG and Osram flat all use the XPG reflector.
    Seating and centring, if necessary, require you to remove the lens to manipulate the reflector. This is quite easy but dare I say easily stuffed up if you're not careful or considered in your operation. I've played with these things a stack of times so it's no big deal to me but could be quite daunting for some? Anyway I'll call that an advice warning of sorts.
    You made an excellent choice with the AA Haiku, the Osram will be a throwy little low power light for sure. My tastes lean towards the 119V or perhaps XPG2 for that configuration.
    I read your PM, I don't use face.... but I'm happy to answer questions or guide/provide tips to get things sorted to the best of my ability for those interested, providing I'm about that is.
    Good to see some goings on in the McGizmo thread, the most important one that is. Been meaning to get some new pics up some time.
    Thought I'd better add a couple of points regarding LE swaps, first off all Haiku reflectors use a tiny o-ring in their base to insulate from the MCPCB and more importantly its contacts. Secondly, Don adds some kapton tape on the contacts as an extra precaution. Thirdly, the pads (contacts) on the MCPCB need to be soldered towards the outside to clear the reflector base (often LEs made for Mules and Sundrops are soldered centrally which would require alteration).
    And finally, I just considered that I've been banging on in Rush's Hive thread and cluttering it up so perhaps should have done so in a different section
  18. #258
    I also appreciate your comments.
    Im starting to research which sundrop configuration to buy from Don
    we started with a cr123 body, 119 with Hive
    but when I asked about moddability to sw45k, he suggested the xp-g2 for the contact pads
    since I can reflow, or replace mcpcbs, Im a bit more curious to see the 119v.. before deciding whether to mod to sw45k
    then I wanted to explore AA Eneloop option (no interest in 14500)
    can you post a photo side by side of 119 and sw45k
    I welcome your comments, since you know the sw45k well.
    It is my favorite.
    my interest in the sundrop is for the beam shape, and I require high cri and high r9, w duv below bbl, and access to sublumen modes without PWM
    so Im holding off from buying Hive until I hear sublumen without flicker is possible
    also wondering, what are the lumen levels of an sw45k on "standard 3S modes, and standard Hive modes"
    I have not yet found any lumen tables for Gizmo LED/driver/battery configs
    links welcome
  19. #259
    In my experience the tint on the 119v, looks nearly identical to the sw45! It has a very nice, slightly rosy tint.
    SureFire - Quality and brilliance
  20. #260
    Quote Originally Posted by K2-bk-bl-rd View Post
    thanks
    almost pulled the trigger, but when it came time to pay.. the sticker shock held me back..
    my concern, beyond price, is the ring around the XRU beam..
