If you have any questions please feel free to send a PM or email. Thank you for looking!!
Sale Terms:
4) Micro ATL G3 Light [SPF on another forum] $60 (ships First Class) $65 $70 $75 $80 $85
Fabricated by sunny_nites over on CandlePowerForums. Aluminum casing. Has 3 warm white leds, charging cable with allen head key to open up charging port, battery volt meter, and split ring. Throw on a ball and chain and you can wear this around your neck. A single click will turn it on to full brightness, about 30 lumens or so. A press and hold from off will ramp up the brightness from very low to max. Continue holding and it will continue through to some flashy modes. UI/driver are from a Photon X-Light Micro.
Sold:
1) ToolVN 10440 AAA Clicky [Sold to RUSH FAN] $110
This is a Lumintop Tool AAA Clicky flashlight that has been customized by vinhnguyen54.
Specs are: DriverVN (v2), XP-L HI V3 6000K led emitter on copper with and additional 3 copper layer heatsink. Runs on a 10440 IMR battery (1 efest is included). Has V54 engraved. Has some minor ano missing.
To switch mode groups:
Rapidly tap the switch 8 times, holding the last tap. The light will then enter the programming mode and begin to flash. With the light in programming mode, tap the switch the same number of times as your desired mode group. The light will blink and your mode group will be memorized.
Example:
To select mode group 3, tap the switch 8 times quickly to enter programming mode. As soon as the light enters programming mode and starts flashing, tap the switch three times (for group 3). The light will blink to recognize the mode group change.
To set the turbo timer:
Rapidly tap the switch 8 times, the light will then enter the programming mode and begin to flash. With the light in programming mode, tap the switch 30 times to enter the turbo timer set mode. The light will then switch to 100% power. When the light is at the desired temperature for the turbo step down, turn the light off. The turbo timer will then be set. Turbo timer drops down to 50% output.
User Selectable Groups:
1 Mode
1. 100
2 Modes
2. 5 - 100 | Memory
3. 5 - 100 | No Memory
4. 30 - 100 | Memory
5. 30 - 100 | No Memory
6. 70 - 100 | Memory
7. 70 - 100 | No Memory
3 Modes
8. 1 - 30 - 100 | Memory
9. 1 - 30 - 100 | No Memory
10. 100 - 30 - 1 | No Memory
6 Modes
11. 1 - 5 - 15 - 50 - 70 - 100 | Memory
12. 1 - 5 - 15 - 50 - 70 - 100 | No Memory
13. 100 - 70 - 50 - 15 - 5 - 1 | No Memory
Specific Functions
14. Strobe
15. 100 - Strobe | No Memory
16. Strobe – 100 | No Memory
17. 100 - Blink1Hz | No Memory
18. 1 - 5 - 30 - 70 - 100 - Strobe – Blink1Hz | No Memory
19. 100- 70 - 30 - 5 - 1- Strobe – Blink1Hz | No Memory
20. 5 - 30 - 100 -Blink1Hz – Blink3Hz - Strobe – Beacon | No Memory
The mode group I have it set for is 11. I do have turbo timer enabled as well.
2) Sky Lumens SL2c Hi CRI [Sold to mikeyx] $70 (ships First Class) $75 $80 $85 $90 $100
This flashlight that has been customized by vinhnguyen54.
Specs are: DriverVN (v2), XM-L2 Hi CRI 2900K led emitter on .3oz copper heatsink. Runs on a 18350 IMR battery (1 efest is included, 2 if I have an extra one on hand). Has V54 engraved. Lanyard attached is included.
Example:
1 Mode
1. 100
2 Modes
2. 5 - 100 | Memory
3 Modes
6 Modes
Specific Functions
14. Strobe
3) Sky Lumens S2+ Triple [Sold] $80 $95
This flashlight that has been customized by kyfishguy.
Specs are: Triple XP-L U5-7A (3000K) w/Clear Narrow Carclo Optic. Driver is a single sided FET driver flashed with four mode star firmware featuring four modes in ascending order with no memory (low-med-high-turbo always starting on low). There is a turbo timer, I believe at 60 seconds. I cannot confirm though as light gets too hot to hold way before. As such, treat this light with respect and handle/use it responsibly. This S2 draws 8.5 amps off an efest purple high drain cell and gets hot fast. Runs on a 18500 IMR battery (1 efest is included, 2 if I have an extra one on hand).
Please note: Battery must be loaded from the head end (positive on battery to head, negative to tail). Doing so from the tail end may affect the spring and may result in a non-working light. Soldering would bring it back to life and use but it is best to avoid the scenario if one can.
Sale Terms:
- Priority Mail shipping included within the US unless otherwise specified
- US Shipping only
- Paypal Purchase of Goods Option (no gift payments please)
- Paypal payment must be received within 12hrs unless previously discussed
- I reserve the right to refuse sale at my discretion
- No trades at this time
Sold:
Example:
1 Mode
1. 100
2 Modes
2. 5 - 100 | Memory
3 Modes
6 Modes
Specific Functions
14. Strobe
Example:
1 Mode
1. 100
2 Modes
2. 5 - 100 | Memory
3 Modes
6 Modes
Specific Functions
14. Strobe
