Hi guys,
I had a H600W Zebralight for the past 3 years I think.
After several holidays, i've been through some rain / humidity travels, and noticed some regular moist build up inside the lens..which took ages to get rid of. :sick2:
All my lights have been taken care of: o-rings regularly cleaned and silicon greased, thread cleaned and silicon greased.
I'm assuming it's the metallic ring around the Zebralight lens that is probably the weak point of this light (or maybe the switch ?)
I'm a "buy quality, cry once" type of guy.
Zebralight were everything except cheap and I'm a bit disappointed by this humidity condensation issue (of course my headlamp is out of warranty now).
Should I consider Armytek ? if yes, what 18650 model would you recommand ? I'm looking for a UI that would be as simple as possible.
A super low, low, medium and high will be just fine.
Maybe Nitecore HC30 ? Fenix HL55 ?
I have absolutely NO NEED for any programmable modes...
Thanks for you help and input.
H
H
