TPellegrini
- Joined
- Oct 12, 2015
- Messages
- 1
Hello All,
I am a design engineer for a lighting company and am looking for some feedback from the most important voices, the customer.
Thank you all for any feedback on this.
- When buying a headlamp, is the inclusion of both nylon and rubber strap important?
- Do you prefer a bright, intense spot or a smoother, more diffused spot?
- What is more important, peripheral light or center beam intensity?
- In your general use, what distance do you require the beam to throw?
- Would you value a custom optic that throws more light down towards the ground and less up to the sky?
- Do you prefer a battery door that is firmly attached with a screw(s) or one that can be snapped on and off without a tool?
- Is there anything not mentioned above that is important to you when choosing a headlamp?
