Fireclaw18
- Joined
- Mar 16, 2011
- Messages
- 2,408
I love modding pocket zoom lights. Here are my most recently modded ones:
These are both modded Aleto N8 budget lights. The stock Aleto N8 is the smallest 18650 zoomie ever marketed at 107mm x 24mm. This wasn't small enough for me, so I modded it.
Version 1: - Aleto N8 with metal button and fresnel lens.
At just 88m long this is quite possibly the smallest 18650 zoomie ever built! The entire light is 4mm shorter than a Sipik 68.
The battery compartment has limited space, but does allow the light to fit 18650 cells up to 67mm long including button top Samsung 30Q, Efest 35A and LG HE4. Works with flat and button top. The flood mode is nearly 90 degrees wide. Much wider than that of a Sipik 68.
Peak throw at turn-on with a fresh Efest 35A is approximately 29k lux. Downside is because the light is so small, it gets hot FAST. Turbo timer is set around 15 seconds or so due to heat. The switch is a soft touch metal button, that requires minimal pressure to activate. The button is small and deeply recessed between a #6 finishing washer making accidental pocket activation very unlikely.
The light is so small that just looking at it, it looks more like a 16340 or 14500 light. The build is unusual in that the majority of the interior of the light is battery compartment. The relatively small pill only extends halfway down the bezel. Typically, lights with sideswitches mount the sideswitch in a compartment ahead of the battery compartment. Not so these lights, where the sideswitch is mounted on the outside of the battery tube and the battery extends below the switch. I like this one for EDC because of it's small size, good tint, extremely wide usable beam and ability to focus. Also, the outer casing is all metal so it's faster to pull out of the pocket than my other Aleto N8.
29k lux. Distance to the tree is 140'
Flood mode beam angle of approximately 90 degrees.
Version 2: Aleto N8 with 20mm aspheric lens and rubber grip.
This one is very similar to the previous light. Main differences are I added a rubber grip to the body tube and installed a 20mm aspheric lens instead of a fresnel. Driver is the same. Due to the more efficient optic, this one is brighter … over 40k lux at turn-on with a fresh cell. The rubber grip around the body tube and rubber button provide exceptional grip, and the button is stiff enough that tailcap lockout isn't necessary for pocket carry. The rubber grip on this light is the "ribbed" portion around the battery tube and is in 3 sections.
Biggest downside compared to the fresnel lens version is its longer length (94mm), and that the rubber grip makes it slightly harder to pull out of the pocket.
44k lux. Distance to the tree is 140'.
Floodbeam is approximately 85 degrees wide. Considerably, wider than the spillbeam on most reflector flashlights.
For comparison, here is a distance shot of the Sipik 68 on L91 primary:
Notice how the spot is barely visible.
Here's some comparison shots showing the width of the flood beams for both Aletos (at 2% power) compared to a Sipik 68 (at full power on a lithium L91 primary).
Some more pictures of the Aletos next to a Sipik 68 with bezels extended and retracted:
