Arif
Hi Collective,
There seems only to be a thread on what I see as a key addition to Nitecore's line-up, for the 'pre-release' version, with a few qualms expressed there.
Feeding back here to allay most if not all fears.
I'm from the UK, and bought the light recently (mid-October). So far my go-to EDC has been the Nitecore P12 - preferring the pre-2015 neutral white version for home use, and the cooler 2015 edition for when out and about/security.
So my main concern had been around whether it behaved on Turbo as though on direct-drive - so simply losing brightness from the outset.
However - it seems that it is genuinely temperature-regulated, as it maintained full brightness for more than 12minutes, where it was borderline too hot to hold - and I didn't let it go on beyond to whatever temperature might trigger ramp-down to the next-lower brightness level.
Batteries were Nitecore's 3100maH jobbies.
Also - there were concerns about parasitic drain, etc. In the instructions, is mention of an electronic lock-out, whereby the light can be stored for a year without worrying about drained batteries. So it seems that they've addressed this concern specifically too.
Finishing is as perfect as ever, which is my experience of Nitecore so far.
Also - it's a perfect walking-light, as is indeed nice and floody.
Lights like this are going to make those like my TM26 redundant, as they start to favourably skew the equation regarding brightness versus size.
Further - it's 'moonlight' mode is really usefully low - supposed to be 2 Lumens, but actually seemed a tad dimmer than my P12's moonlight, which is supposed to be 1 Lumen. But this means that it's good for middle-of-night use, as well as flooding the back garden!
Certainly not as EDC'able as the P12, which I still think is the perfect EDC light.
I do miss though that it's voltage-indicator system no longer indicates exact battery voltage (as it does say on the P12) - but just wide thresholds of >50%, <50%, or 'Depleted'.
So all-in-all - they've addressed the issues that I was most concerned would make the light not worth buying (for me) - namely the indication in the pre-release version of non-regulated drive.
Hope this helps some others decide either way!
Arif
Arif
