Die casting is a
metal casting process that is characterized by forcing
molten metal under high pressure into a
mold cavity. The mold cavity is created using two hardened
tool steel dies which have been machined into shape and work similarly to an
injection mold during the process. Most die castings are made from non-
ferrous metals, specifically
zinc,
copper,
aluminium,
magnesium,
lead,
pewter and
tin based alloys. Depending on the type of metal being cast, a hot- or cold-chamber machine is used.
The casting equipment and the metal dies represent large capital costs and this tends to limit the process to high volume production. Manufacture of parts using die casting is relatively simple, involving only four main steps, which keeps the incremental cost per item low. It is especially suited for a large quantity of small to medium-sized castings, which is why die casting produces more castings than any other casting process.
[1] Die castings are characterized by a very good
surface finish (by casting standards) and dimensional consistency.
