Hi folks. I find myself using my G25C2 less and less because of the misbehaving twisty head. I've cleaned the contacts head and tail with DeoxIT gold, and tried a couple of different 18650 cells. It behaves the same with both cells:
Symptoms: Normally it goes direct from least bright mode to turbo mode, missing the two intermediate brightness modes. This is really annoying as I rarely want it on either full bright or minimum - normally I want something in between.
Sometimes it flickers off between modes. And then, sometimes, for no apparent reason, it behaves normally. I'm aware of the different tactial and AUX modes as specified here http://eagletac.com/html/g25c2/index.html, but sometimes the light ends up flashing or strobing in a way not documented in the UI.
So, what am I doing wrong? How does the mode selector work? Is it a pressure thing? Where should I focus my efforts? Or is it just an unreliable system? My friend has a light with a single switch that you can scroll through different modes with. Perhaps solid state is better than the unrealiable twisty action from which I'm suffering.
Anyone else have problems like this? I can post a video demo if required. I'm off to the jungle next week so could do with sorting this before I leave! Thanks, have a good day.
