product description
Fenix SF18 adhering to strong, powerful, fully waterproof design ideas for harsh outdoor environments. It has four brightness stalls and a variable frequency strobe mode, the maximum brightness of 950 lumens, spot uniformity soft, smooth and natural. Head-side press a button to control different brightness and strobe mode, convenient; plus tactical ring, aluminum attack head, tail tactical switch light touch and waterproof to IPX-8, I believe both are on duty, hunting, or search and rescue, SF18 are worthy of your trust and good partners.
Product Features
Use Cree XM-L2 (U2) LED, lifetime 50,000 hours
• Use a 18650 rechargeable lithium-ion batteries or 2 3V CR123A lithium batteries
· 147 mm (length) x 25.4 mm (diameter) x40.5 mm (cylinder head)
· Weight 150 g (without battery)
· Constant current circuit, constant brightness
Low pressure alert to remind you to change the remaining battery power while charging low
· Anti-reverse design prevents the battery installed against circuit harm
· Anti-roll, slip the barrel design
· Tail tactical switch, light touch
· Neck dimming button, a key shift dimming
Adopt aviation aluminum manufacturing
· A wear surface processing Army regulations three hard anodizing
• Use double-sided AR coating glass lens
Optional accessories
