alternety
My emergency light is a TK75. I want something that can make a lot of light for awhile, and a lower level of light, for a real long time.
The problem: everyday use as the light aside of the bed vs real SHTF use. I want to run the light in SHTF mode with balanced cells. I have 3 extra extension tubes for this condition. Next to the bed, it is sufficient to have one battery segment. So, the idea is that the normal configuration is 1 extension segment. If SHTF I want to go to 3 extensions. I don't want to just add 2 segments to the daily use single segment to avoid mismatched cells. I may never use the light in single extension form enough to unbalance the batteries. But, then again, I might. So; I plan for worst case.
Solution. ! extension tube for normal use and a different 3 tube extension for SHTF. The idea is to keep 3 battery packs in the the assembled three extensions until needed; then replace the everyday single extension. I would like to store the 3 battery packs in the extension tubes, so I can simply replace the everyday tube with the 3 tube configuration. This speeds things up and minimizes the issue of figuring out how to store individual loaded cell holders, and makes the change faster. Time may be of the essence.
The issue is keeping the batteries in the replacement 3 tube configuration. I can probably buy a tali cap (probably at a silly price) but I need something to screw on the front. Duct tape to hold in the batteries seems like the wrong approach.
Does anyone have any idea where I could get a male end piece (cap) to fit on the front (where the light will screw on) to contain the batteries in storage. I would put some insulation in the inside of this front piece to keep the top of the cell stack from shorting to the case (which I would view as a bad thing).
Perhaps some of you guys that make lights out of chicken manure, some wire, and mysterious metal pieces could point me at something that would fill the bill.
