kj2
Features:
• Dual button tail switch for quick, one-handed operation. No need to fiddle with switches in two different places
• Mode switch provides good tactile feedback and is very easy to locate in the dark
• Strobe can be activated with the Mode switch when the flashlight is on or off, giving instant access to Strobe from any mode
• Forward tactical main switch with momentary activation
• Maintains constant brightness with super high efficiency
• Max output:1060 ANSI Lumens on high
• Max run time: 145 hours
• Reverse polarity protection protects flashlight and battery from damage
Specifications:
• CREE XM-L2 U2 LED with a lifespan of up to 50,000 hours
• 3 lighting modes and 1 flashing mode
• Working Voltage: 3.5V-6.4V
• Battery: 2x CR123A / 1x 18650 (Do not use 16340 batteries)
• Reflector: Textured orange peel reflector
• Net weight: 126g (Excluding battery)
• Dimensions: 145mm(5.7") (Length) x 33.6mm(1.3") (Head) x 25.5mm(1.0") (Body)
• Material: Aircraft grade aluminum
• Waterproof to IPX-8 Standard (underwater to 2 meters)
• Lens: Toughened ultra-clear glass
Specifications:
