Nite Ize vs TerraLUX for a 2-3 C/D size mag:
Nite Ize $7.99. TerraLUX $22.
NI is 55 lumens TL is 140
NI has a fairly cool beam. TL is more neutral.
Nite Ize fits any light that has the edison size n style bulb. Or any halogen n xenon of the same retainer as the mag lite.
TerraLUX is larger in diameter and keepers for the Mag xenon has to be drilled.
Now in use other than a slightly cooler beam I could not see enough extra output from the TerraLUX to warrant nearly 3x the price.
Maybe the TL is more durable? Time will tell. But I was bummed to have to modify my flashlight in order to get the keeper over the module.
Pix were auto white balanced. There isn't any green in the TerraLUX beam in real life.
^^ you saw the Nite Ize package in the previous post
^^ TerraLUX wall shot at 10'+/-
^^ the Nite Ize
^^ the TerraLUX throw
^^ Nite Ize throw
As you can see the neighbors car and shed are slightly illuminated in the TerraLUX beam.
Beam shots confirmed my indoor suspicions...that there aint a nickles worth of difference from either module in real world use.
The TerraLUX is brighter. (as seen in the throw pix) But not by much. At least in a xenon converted 2D Mag.
^^ using these to install a drop in aint cool imo.
Bottom line imo, either one is fine. But, bar-ing durability/reliability issues I'll buy TerraLUX modules for incan mini mags and Nite Ize for C/D size Mags.
Plenty bright for finding your way around without all that flashback in close quarters situation for about $5-10 less than the blue beam LED models.
