Ok thanks for the help! I'll probably try 1111deals then and start out with 8 AA Enelopes. Was thinking about buying AccuPower IQ-328 charger for $25 shipped too (ebay). I just became interested in rechargeables and plan on using them in tv remotes, bike light (takes 3 AA), flashlights, and ordinary household uses. I just bought some Ni-Zn's but doubt I'll like them long term due to problem of them becoming worn down if not careful about recharging. Just recently bought those because of the high current rating but that's before I seen how good Eneloops apparently are. My old non-lsd NIMH's underwhelm me due to how fast they discharge on their own. After researching nimh vs nizn vs li-on it appears Eneloops are the way to go for ordinary uses like remotes, flashlights etc. Someone correct me if this not the case, thanks!
I just opened up one of my two 8 AA packs of Eneloop Glitter Anniversary edition, which is stamped 09-2012, so 3 years old, plus 2 months. The 8 AA beauties were also microstamped: 09-2012--38 months old, as well. These are Generation 2, 1500 cycle versions, Made in Nippon! They're sexy, lol.
Out of the pack voltages:
1.292v
1.292v
1.292v
1.292v
1.292v
1.292v
1.292v
1.292v
Notice anything? Quite consistent on my decade old RatShack 22-805 DMM. A couple bounced one tick higher, but settled at 1.292v.
On my Maha C9000, discharged at 300mA, the results are:
1211mAh
1226mAh
1197mAh
1210mAh
1219mAh
1215mAh
1208mAh
1215mAh
Average is 1216.6mAh, extreme spread is 29mAh, so we're looking good there, as well. Internal resistance (I.R.) after discharge and upon 'break in' are for 1-4 above:
1.48v
1.43v
1.49v
1.46v
This is inline with newer battery numbers and they might even drop a bit after break in.
Remember, Eneloops aren't fully charged from the factory, but something like 70% using solar, as the rumors have it. Gen. 2s are marked 1900mAh minimum, like most generations and we can get from the mid 1900s to the lower 2000s depending on what charger we're using.
As you can see, even if they were fully charged from the factory and I use the 2000mAh typical number that we see, I'm still at 60% of that inflated number.
Now, whether they crap out on me sooner, rather than later, I can't say. My first quad is still breaking in on the Maha, but I expect things to be consistent with pretty new stock.
I've posted about the Utah Eneloop sellers on Ebay above and the one fellow states that the freshest batch of FDK (maker of Eneloops) made AA 'Eneloops' in America is June of 2015, FWIW.
He's a big buyer of Fujitsu labeled batteries and Panasonic Eneloops (FDK is a subsidiary of Fujitsu and owns the patents/factory that produces Eneloops.)
Buy any known FDK made cell and you should be fine. I've recently bought 8 Gen. 4 (2100 cycles) Fujitsu AAs and I got 4 Fujitsu 2450mAh (Eneloop Pros/Duracell Ion Core) AAs with a Fujitsu power bank.
Chris
