Mean Well LDD-1500LW driver and 4 Cree XMl's .... Wiring in series or parallel?
KidFrost
If I wire them in series will they each get 1500 mA or would that be split between the 4?
I believe if I wire them in parallel I will each get more mA to each LED therefore they will be brighter?
Thanks in advance
yazovyet
wire in series (+ to -, + to -, etc) and they will each get 1500mA. in parallel (all + together and all - together) and they will split the 1500 to each get 375. remember that your voltage input must be at lest 3 volts higher than the LED string.
Microa
Hong Kong
I think you have three options.
1) 4S 1500mA each LED 306.9lm 3.14V 4.71W. Total 4 LEDs 1,227.6lm 12.56V 18.84W.
2) 2S2P 750mA each LED 166lm 2.92V 2.19W. Total 4 LEDs 664lm 5.84V 8.76W.
3) 4P 375mA each LED 85lm 2.77V 1.03W. Total 4 LEDs 340lm 2.77V 4.12W.
If you want the brightest output, you should connect them in 4S and the supplied voltage higher than 14V.
KidFrost
I am powering them with a 20v Max dewalt power tool battery. Not sure how the get 20V from li-ion cells though. 3.7x6 = 22.2V, either way I will be over 14v.
Microa- Can you do the math on 4S 2100mA each for me like you did up here? ^
Might switch to a Buck Puck 0A009-D-V-2100, 2100 mA constant output driver.
Thanks alot for the help!
Microa
Hong Kong
A full charged li-ion cell is 4.2V and which should be cut off at 2.5 - 2.8V. So 5S li-ion cells should be adequate. 2.8V x 5 = 14V and 4.2V x 5 = 21V both values are higher than 14V mean that the LEDs are all in current regulated during the whole battery discharging period.
4S 2100mA each LED 400lm 3.26V 6.84W. Total 4 LEDs 1600lm 13.04V 27.36W. Please note the lumen output is at Tj = 25C. You can find your required data at pct.cree.com/dt/index.html
