Hi All,
Couple of months ago i adjusted my LED from my fluval edge 2.
I used a digital timeclock (din rail) to switch between the blue and white led's. In daytime the blue and white are on together and in the night only the blue lights are on.
See scheme above. As you notice the common is + using to switch between night and day. This has to do with the internal setup of the Fluval LED unit.
Now i tried to connect it to the new milight controller. with the scheme below
The issue here is that it only uses one common + that has constant voltage. So currently im only able to use one LED. Is there any solution for this? As there is on the unit only one minus and two plusses.
