MikeSalt
For submission in the Reviews section please.
I've been out of the CPF loop for a while now, which has been quite nice in a way because the technology has come on leaps and bounds. The limit for a single emitter die was about 300 lumens last time I was seriously involved, now we have four-figures. Crazy :duh2:
Having realised that such powerful emitters were available, the prospect of owning an EDC of comparable output to my Roar of the Pelican hotwire was too tempting, and after some research, I purchased the Nitecore EC11, an i2 charger and a couple of 18350 IMR cells. On paper, this seemed to do it all, with the high output, keychain size and red LED all in one package.
Clipped in Trouser Pocket
Size in Hand
Red LED
Main Beam
Pros
Tiny.
Decent Pocket Clip.
Huge 900 Lumen Output in Turbo (more than Roar of the Pelican Hotwire).
Red LED.
Strobe, Beacon and SOS modes well hidden.
Orange-Peel Reflector gives excellent main beam.
Battery Voltage Meter.
Ultra-low has no visible PWM effects.
Direct access to Ultra-Low.
Direct access to Turbo.
Direct access to Strobe.
Direct access to Red LED.
Guilt-free lumens when used with IMR 18350 cells.
Rectangular cut threads.
Cons
User Interface takes some getting used to.
Easily activated when carried loose in pocket, either lockout tailcap or clip in pocket.
Niggles
CR123 primary use requires the use of a sleeve. Chances are, if you need to use CR123s in an emergency, you won't have that sleeve.
To ensure main beam quality, red LED is heavily recessed, giving a poor beam.
Low, Medium and High are achieved through PWM.
Verdict
Of course, there are some obvious compromises, and specific needs would be better served with dedicated torch. However, if I were to have the choice of just one "Do It All" torch on my person, this would be the one :thumbsup:
Size in Hand
Red LED
Main Beam
Pros
Tiny.
Decent Pocket Clip.
Red LED.
Cons
Niggles
Verdict
