RNLAF
Hi Guys,
I'm pretty new here on CPF but I have been reading a lot. I'm both a professional as a volunteer firefighter and I'm looking for good flashlight. Now, I know a lot has been written about firefighter flashlights on this forum because I have read a lot of those posts. The consensus seems to be that a "throwy"light "cuts" true smoke and works best for a firefighter.
I have been a career firefighter for 16 years, the last 5 of them also being a volunteer. 10 of those 16 years I have been an instructor. In a smoke filled enviroment I prefer not to use a flashlight at all. Most of the light reflects right back at you making it even harder to see anything. If you are looking for the seat of the fire true thick smoke, you are better of using now light at all. When locating a possible victims in a smoke filled house a throwy flashlight does seem to work a little bit better then a floody light. But these day we are no longer using flashlights to locate body's in a smoke filled building, we use thermal imaging cameras. If you have ever used one of these things, you know it will hands down outperform any flashlight in fire conditions.
One thing I haven't seen in any of the "firefighter flashlight" threads is what color light helps me see the true color of the smoke? Smoke or fire gases are combustible and with todays insulating materials and many different plastics, its even more combustible as it was before. Nowadays its highly important to "read" the smoke. What is the color of the smoke? How dense (optical and physical) is the smoke? What is the volume of the smoke? How does the smoke "flow" true the structure (laminar or turbulent)? Firefighters need this information in order to determine what stage the fire is in and how the fire is developing. This information needs to be as accurate as can be. A rule of thumb is that thicker, darker (dark gray to black) smoke is more combustible. This has a lot to do with the amount of CO and Carbon/soot in the smoke. But, light gray colored smoke can also contain dangerous levels of combustible gasses. Smoke can even color yellow or brown which could indicate that the ignition temperature of the smoke could be lower then the usual 600 to 650 degrees C. Hence the importance of a good flashlight that has good throw in order to asses the density of the smoke and has the right color in order to see the actual color of the smoke.
Now, it is my experience that incandescent lights have a yellowish color so they tend to mislead you when you are trying to determine the color of the smoke. LED lights usually are better but they also have many different colors.
I don't have much experience with different LED flashlights. We use to have MAG lights, later followed by Streamlights SL-20XP with a halogen light and 3 small LED's. These lights are rubbish. The light color of a new halogen light is reasonable but after a couple of burn hours or when the battery starts to drain, the color turns brown. Furthermore, where do you put those Streamlights on/in your turn-out gear when you need both hands to do a job!? And when you lay them on a table they always role of...
At work we have Streamlight Survivor LED lights. Huge improvement. Good bright beam and good throw as well. A right angle light with a clip on the back is simply great. But sometimes I'm not sure about the color. It seems a bit blue. Does it provide the right color of light to determine the actual color of the smoke?
Does anyone have an idea on what color light would be best to determine the actual color of smoke?
And maybe someone can explain why firefighter flashlights are so much more expensive in Europe then in the US? In the Netherlands the cheapest Streamlight Survivor LED I could find cost €113,- ($123,-) and a quick search for a US based seller tells me one only needs to pay $63,- for the same light! that's almost a 100% price difference! Does anyone of you Americans plan on traveling to the Netherlands any time soon? And if you, do you have some spare room in you luggage the size of, lets say a Streamlight Survivor?
Hope to hear from you guys!
